Multi room audio help
Discussion in 'AV Receivers' started by Ryan*D, Aug 28, 2005.
  1. Ryan*D
    Ryan*D Agent
    May 15, 2005
    30
    New poster here but long time reader.
    Were setting up a Dedicated Home Theater room. Pictures of the progress will be up soon. The house is studs right now so i would like to wire up for the speakers.
    We want to have audio in the kitchen, great room and outside by the pool.
    so thats 3 zones. Audio all at once or 1 at a time.
    There only for music.
    I would like to have volume controls in all 3 rooms and I'm not sure if I would need a switch to turn the speakers on/off in each room/outside. 2 speakers in each room and outside.
    I'm going to use the Denon avr-4806 for the HT. 7.1 going in.
    I'm new to multi room audio so please forgive me.
    What else do i need to get this to work? Where do i find the volume and on/off switches?
    any other amps?
    thanks for the help
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    The easiest way is probably to use a hub to do the distribution and impedance matching switches in the respective locations. I would recommend using a separate amp to drive the other zones.
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
  5. Ryan*D
    Ryan*D Agent
    May 15, 2005
    30
    what if i got the Denon AVR-5805 insted?
    it says it can do 4 zones.
    it has 3 pre outs.
    how would i use this?
    this reciever is a monster. it's has alot of plugs
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    You'll still need/want volume controls in each room. The 5805 can power multiple zones because it has some extra assignable amps. That's a thought, but it's also more money than volume controls and a hub AND a multi-zone or multichannel amp are going to cost you. Then you'll have one hell of a receiver though.
  7. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    How many sources, tuner & cd only?
    You can get a 6 channel amp for 3 rooms running it to the volume control and then to the speakers.
    How far will the wire run?
    I had a hard time running to the kitchen....maybe 120 ft from source to speaker(not as the crow flies)
    Sounded fuzzy until I put my McIntosh amp on 2 ohm because of impedence build up.
    Heavy guage wire will also work for over 100 ft too.
    Under 100 generally not a problem
  8. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    Sonos seems a fit, and probably cheaper overall than the 5805 (not sure)
  9. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
    Rotel has also introduced some new amps at CEDIA designed for custom AV installation with gain controls on front (they are rack mountable):
    RKB-250 2x50WPC $550
    RKB-650 6x50WPC $900
    RKB-2100 2x100WPC $800
    RKF-100 Fan Cooling Kit $400
  10. Ryan*D
    Ryan*D Agent
    May 15, 2005
    30
    thanks for the help guys.
    We decided not to run the speakers to the HT equpiment.
    We ran them to the bar. Just going to get a stereo and a amp.
    Thanks again!
