Multi Monitor/TV out
Discussion in 'Computers' started by Phil L, Jul 31, 2004.
  1. Phil L
    Phil L Supporting Actor
    Dec 27, 1998
    782
    I'm having trouble setting this up, I'm probably doing something wrong or have skipped some obvious first step.
    I have an ATI Radeon 9800Pro card. I'm trying to set it up so that I can get video out through the dvi port.
    I've got it set up, and I get a screen on my TV but whenever the dvi cord is hooked up and the TV is on, I lose picture on my main monitor.
    Help?
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    If you haven't done this before, it is easy to miss. The cord has to be attached before you boot up. I know, really weird.
    Glenn
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    check in your display settings, windows tends to start up with only one display device so you'll need to turn the other on yourself.
    I would reccomend using the theater mode which can be adjusted in the advanced menu.
  4. Phil L
    Dec 27, 1998
    782
    Did that too.
    Haven't been able to change the resolution of my monitor since though.
    Now I have to work on that and Powerstrip, y'know, the simple stuff now that I've got picture[​IMG]
  5. Phil L
    Dec 27, 1998
    782
    Now I can adjust the monitor res but not the TV/DVI res.
