Multi channel setup on Sony C555ES SACD player
Discussion in 'Archived Threads 2001-2004' started by Joe Wong, Oct 29, 2002.
  1. Joe Wong
    Joe Wong Second Unit
    Jun 8, 1999
    378
    70
    Hi,
    This may be a silly question...but what's the difference between 6 ch direct output and 5 Large + SW output when setting up the bass management option on the SCD-C555ES? Isn't 6 ch direct assuming 5 Large speakers + SW anyway, since 5 L + SW doesn't redirect bass? Or am I missing something?
    Thanks!
    Joe
  2. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,071
    3
    Joe, I just got a SACD player, and I never thought of that. That's a very interesting question..hopefully someone will have an answer..[​IMG]
  3. Joe Wong
    Jun 8, 1999
    378
    70
    Anthony,
    I was just thinking...maybe the 6 ch direct is 6 full range signals, and 5 L + SW = 5.1 (the .1 equivalent to a LFE channel) signals? But this may imply some form of bass management?
    This raises another question...are most SACDs mixed for a 5.1 style output? I think Chesky has some 6.0 (6 full range channels) recordings.
    Cheers,
    Joe
  4. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    6 ch Direct provides no bass mgmt. Whatever is encoded in each of the 6 channels is passed through unaltered. I believe 5L + SW would duplicate all bass from the 5 channels at and below the crossover and send to the SW out, while also sending this out in the 5 ch outputs. I'm not sure what happens to stuff encoded in the .1 channel that is above the crossover, though.
    Doug
  5. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,904
    10
    From what I understand, DVD-A and SACD can offer 6 full range channels, as opposed to DD and DTS which are 5.1 (although now with EX, I guess that would be 6.1) with the .1 LFE plus main channel bass if you have bass management.
    For SACD and DVD-A the 6th channel can be anything; even a height channel for a ceiling speaker.
    FWIW, I don't think there are any multichannel SACD r DVD-A titles that do anything other than 5 channels (or sometimes less, if the center is not used) w/o sub or possibly 5 channels w/sub.
    My player (Pioneer 45A) refers to the analog outputs as 5.1, which I guess is not completely correct in a SACD or DVD-A environment.
    I am not sure how my player would handle a title that had full range signals on the 6th channel. If I had Sub On, that would be low pass filtered at about 100Hz. If I said Sub off, I would think that the 6th channel would be turned off.
    No matter. I run my mains set to small and my sub on, since I do not have full range speakers at all channels. I guess I would only be hosed if I had SACD or DVD-A software using the 6th channel for something other than sub/LFE.
    Does anyone remember a day when you had two channels to worry about, and BM meant a trip to the john?
    BL
