Multi-channel cables
Discussion in 'Archived Threads 2001-2004' started by Bill Blank, Sep 5, 2002.
  1. Bill Blank
    Bill Blank Stunt Coordinator
    Sep 3, 2002
    222
    Does anyone make multi-channel preamp-->power amp cables or am I stuck buying 3 pairs and having one left over?
    Bill
  2. David_Rivshin
    David_Rivshin Second Unit
    Dec 13, 2001
    350
    The only such set of cable I've seen is an IXOS 6 channel cable sold by www.accessories4less.com, however I don't think that they are particularly cost-effective, and you'll end up with a (useless?) extra on both ends... always room for 6.1 audio, perhaps? [​IMG]
    If you only need 5 channels, how about getting 2 2 channel cables and a 1 channel of the same make? Some heat-shrink tubing could help with organization and looks. You could also get 3 2 channel cables, and separate one of them, getting you a cheap subwoofer cable in the deal [​IMG] Another option might be 3 a channel audio-video cable and a 2 channel audio cable where the audio cables are identical to the video, which is usually the case. As always heat-shrink tubing can clean things up abit.
    Where there's a will, there's a way [​IMG]
    -- Dave
  3. Tom Boucher
    Tom Boucher Second Unit
    Mar 1, 1999
    280
    catcables.com has a 5-AMP Cable that does what you want. Five interconnects in one cable.
    Going to get one soon I hope. Need to update my cables from the ones I've had for the last, oh, 15 years (and not all of them were bought at the same time, little here, little there)
  4. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    Just go to any of the on-line custom cable makers
    (Bettercables.com, RhinoCables.com, Catcables.com etc.) and you can buy the exact qty you need with no left overs.
