Msi TI4200: Can't save overclock settings
Discussion in 'Archived Threads 2001-2004' started by Jeff, Jul 10, 2002.
  1. Jeff
    Jeff Supporting Actor
    Jun 30, 1997
    948
    110
    Does anyone with this card, or one close to it, know why I can't save the settings in the MSI Clock tab? I can change them but when I reboot, they are back to normal.
    Jeff
  2. Kami
    Kami Screenwriter
    Jan 2, 2001
    1,490
    That's strange. I too have the MSI card but I never even bothered with their drivers...I just immediately installed the latest nvidia reference drivers, since companies like MSI don't really update their drivers all that often.
    So try installing the reference drivers from nvidia.com, then get the coolbits hack to allow overclocking:
    http://www.overclockers.com.au/files/CoolBits.reg
    (just run that file and it will enter it into your registry)
    After applying that coolbits thing, go into your display properties and the "Additional properties" of your GF4, then the clock speed tab and check off the "allow clock adjustment"...then you will have to reboot and you should be able to overclock fine from there.
  3. Jeff
    Jun 30, 1997
    948
    110
    Actually it does work with the MSI drivers. I was wrong, but you have to use that 3D Turbo Experience GUI that runs off IE. And I don't think you can get precise settings but that's no big deal for me.
    Anyway, thanks!
    Jeff
