Stan T
- Mar 2, 2001
Is there any software that will allow you to burn a data disc of MP3's & change the position of songs? I have Easy CD creater (version 3.5C) & in the help section it says after you have the MP3's in the layout window you can drag songs into the position you want. It automatically puts them in alphabetical order when you first put the MP3's in the layout window.
However I can't get the software to allow me to drag songs to different places to put them in a different order. It will do it on a regular CD layout for wave files but not a data CD with MP3's. According to the help section it says you can do it on either. Does someone have this version & know how to do it or recommend a software that will allow me to do this? Thanks for your replies.
