movies in DTS 96/24
Discussion in 'DVD' started by Mike Mundt, Jul 16, 2003.
  1. Mike Mundt
    Mike Mundt Stunt Coordinator
    Dec 28, 2002
    64
    are there any movies in DTS 96/24 or is it all music dvds. I cant even find a list of available dvd music with a dts 96/24, it seems like the only way to find them is to go into a store and look at the back of every dvd.
    im really interested in finding if theres any movies in dts 96/24, but a list of music dvds would be nice too.
    thanks in advance
  2. Jason Whyte
    Jason Whyte Screenwriter
    Jun 3, 1999
    1,439
    Moving to software...
  3. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    As far as I know there are no Region 1 movies with DTS 96/24 encoding, but there are a few DVD-Audio music discs with a backup DTS 96/24 track (the MLP encoded PCM 96/24 tracks on those would be superior anyway if you have a DVD-Audio player).
    Dan
  4. Jason Perez
    Jason Perez Second Unit
    Jul 6, 2003
    310
    Hello Mike!
    I was interested in this same thing, and the last time I checked (about 3 weeks ago), it seems that the only movie available was the Italian version of Tomb Raider. I am not sure, but I think that qualifies as Region 2. Hopefully, as time presses on we will see some releases stateside. I have a couple of the Queen DVD-Audio Discs, and auditioned the DTS 24/96 tracks. To my ears, there was a definite improvement over "standard" DTS. [​IMG]
    Jason
  5. DeanWalsh
    DeanWalsh Second Unit
    Apr 17, 1999
    390
    Yes the Italian dvd of Tomb Raider is the only movie available in this format... however the track in question on this dvd is Italian language.
  6. Kristoffer
    Kristoffer Second Unit
    Dec 8, 2002
    460
    The Two Towers Exentended, Matrix Reloaded, X men 2 and so on would be great to have in 24bit / 96 Khz!!!
    But is there room for it? And would there be room for a 5.1 track as well??
  7. RobD
    RobD Second Unit
    Jan 21, 2003
    264
    I think the more importantant questions is do these movies have the soundtrack masters recorded in 96Khz because upsampling will not give the same quality.
  8. Eric F
    Eric F Screenwriter
    Sep 5, 1999
    1,810
    But movies with analog masters would benefit from this greatly. Eventually all movies will even eclipse 96/24bitrate.
    Unfortunately DTS 96/24 needs a fullbitrate DTS track, and since they're not done anymore it's doubtful we'll ever see it on DVD. Maybe HD-DVD...
  9. RobD
    RobD Second Unit
    Jan 21, 2003
    264
    Interestingly the 96/24 full bit rate track will sound better than halfrate even for those with standard DTS only decoders. This is because 1.0Mbit is standard DTS and .5 Mbit is the extended 96/24 information.
    Its about time we saw some 96/24 film releases, it is pretty much the best multi channel sound available on DVD-V.
  10. Mike Mundt
    Dec 28, 2002
    64
    first of all...........thanks for all the help everyone
    Eric F:
    i have the full bite-rate version of Lethal Weapon 1 Directors Cut, so that is a sampling rate of 96 kHz?
    Kristoffer:
    to the comment about having Two Towers in a 96/24 format, that would be great, but then you would lose the DTS-ES 6.1 discrete mix, sort of a bummer. Matrix Reloaded i could definitely go for a 96/24 mix as well as X-men 2 like you said.
    RobD:
    Im not familiar with movies, but most major music recordings are done at 192 kHz sampling rates
  11. Dan Hitchman
    Jun 11, 1999
    2,713
    Standard full bitrate and half bitrate DTS DVD tracks use 48 kHz sampling. Depending on the master used it could be 20 or 24 bit resolution.
    DTS CD and LD tracks use 44.1 kHz sampling and 20 or 24 bit resolution.
    The full 1.5 Megabits/sec data rate is not completely utilized anyway for standard DTS, so adding the extension file doesn't lessen the "core" data that much.
    I would much rather have HD discs using PCM 24/96 (and higher) or DSD than DTS or Dolby any day of the week, and twice on Sunday. We shall see what the studios and manufacturers agree on.
    Dan
  12. Eric F
    Eric F Screenwriter
    Sep 5, 1999
    1,810
    Mike, ignore the "96/24" part in DTS 96/24. It's a totally new format. I think it's intentionally named to confuse- hell, even I was confused by the name. You need an entirely new decoder to use the format.
    Think of the format like HDCD is on CD. There are extra bits to each format, and in order to decode them you need to have the right hardware. So, even though HDCD encoded CDs can be played on any CD player at 44/16, you need HDCD support to get the extra "bits" (20bit). Same goes for DTS 96/24- it will decode on any standard DTS decoder to 48/16, but needs specific "DTS 96/24" support to get decoded in 96/24.
    Lol. Shame on DTS for trying to cloud the issue. A better name would have been "DTS Deluxe" or "SuperDTS", something like that.
  13. Mike Mundt
    Dec 28, 2002
    64
    Eric F:
    thanks for the explain but lucky i read on cnet a few weeks ago about 96/24, had i not read it there, i would have just learned it now though [​IMG]
  14. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    Does anyone have a list of all the DTS 96/24 DVDs available?
