Movie Sub Output And Volume
Discussion in 'Archived Threads 2001-2004' started by AbelM, Jan 15, 2002.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    For movies do you guys' usually turn up the volume on the sub or the putput level, just for a little more punch? I just stared doing this, and it is better IMO. I mean I have it around 11db output level for music, games, etc..., and for movies I go up to about 7-6db!
    What about you guys'!?
  2. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    I usually turn mine up to watch movies just so I can feel the couch rumble more. It definately is more boomy, but I think it sounds good for HT bass. I use the Sony SAWM40 by the way.
  3. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Anyone else?
  4. Robert Barker
    Robert Barker Stunt Coordinator
    Oct 22, 2000
    66
    I run mine about 4db Hot. I listen to Movies about 10db under reference.
    Robert Barker
    Austin TX
  5. Alan Pummill
    Alan Pummill Screenwriter
    Jul 6, 1999
    1,262
    Hello AbelM,
    I have a Velodyne CT-120 and I also turn up the sub during movies.
    I turn it back down during CD listening. My fronts are Paradigm Monitor 7's. When I set my receiver to Direct mode during CD playback, it's just too much mid-bass. I prfer listening to CD's in stereo, not surround.
  6. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    So do you guys' up the volume on the bass it self, or the output level?!
  7. Jerry AZ
    Jerry AZ Stunt Coordinator
    Dec 7, 2001
    151
  8. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I turn it up with the receiver's level, not the sub's amp knob.
  9. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    So you guys' mean with your output level right? Becasue I don't think I can turn the volume up on the reciever for my sub on mine...the Yammy 520. Or am I not getting it?!
  10. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Your receiver should have a sub level control. I have the 620 and to get to the menu I have to set the remote to DSP or AMP and push the
  11. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Isn't that what I said? I thought you guys meant output level right? The one that goes up to 0 and down to -20.0??
  12. Barry BB
    Barry BB Stunt Coordinator
    Nov 28, 2001
    168
    Um... maybe you should read again what you said?
    >>>"Becasue I don't think I can turn the volume up on the reciever for my sub on mine"
    The above responses were refering to setting the sub level with the receiver's controls.
  13. Alan Pummill
    Jul 6, 1999
    1,262
    AbelM has a hard time expressing himself sometimes! Forgive him for he is a Newbie!
    Abel, I turn the volume up on the sub itself for movies.
  14. Barry BB
    Nov 28, 2001
    168
    I was not trying to be mean spirited. Sorry if it came across badly.
  15. ColinM
    Dec 9, 2001
    2,050
    A -
    You are probably trying to tweak the 'LFE', that usually cant go above '0'.
    Look for the sub control, not lfe.
    Leave the LFE at zero.
  16. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Yeah I know I do leave my LFE at 0, but I have a setting called sub out put level, and I just turn that up or down...up makes it less boomy and down makes rael boomy...
    And Barry BB:
  17. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    It sure does make a difference. I tried that for Vertical Limit and Terminator 2 UE.
  18. ColinM
    Dec 9, 2001
    2,050
    "I don't think I can turn the volume up on the reciever for my sub on mine..."
    Why not? LFE won't go higher than zero. Sub level will.
    You asked -
    "for movies I go up to about 7-6db!
    What about you guys'!? "
    We answered, and now you want to know the best way to do it?
    Adjust the rec's sub level, I say. *BECAUSE* once you calibrate the system, you DON'T want to go twisting the volume knob on the back of the sub, because you'll likely never get it back to the same spot again, meaning you will have to calibrate all over again.
    If you do it by ear then screw it. Twist away.
    - CM
  19. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Thanx Collin...Appreciate it!!
