ale peinador
- Dec 11, 2006
- Alejandro Peinador
Hello everyone, my first post here after several months of lurking around and learning from other's posts. You have all been really helpful without even knowing, thanks.
I just bought a JBL S-Center on eBay and thanks to that I finally upgraded my fronts from the JBL N26's to the S36's to match the S-Center.
I want to install the S36's on mounts and have searched a lot thru the forum but the only posts I found are really old and point to brackets no longer available.
I'm desperate, If anyone knows of mounts or brackets available now that will fit the 2 threaded holes on the bottom of the S36's please point me in the right direction.
Thanks.
Thanks.
