Mount two Klipsch Promedia satillites.
Discussion in 'Speakers & Subwoofers' started by JamesAH, Mar 8, 2004.
  1. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    I picked up some speaker stands at Wal Mart. I am not sure how to mount these. Do I just use the adhesive?
    Thanks.
  2. ken nomimashita
    Jan 28, 2004
    30
    i have klipsch promedias. not bad for computer speakers.
  3. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    Not at all. Got a 2.1 system for $100 refurbed at Klipsch.com.
    Now, back to the topic at hand.
  4. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    Surely someone has done this...
  5. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    C'MON!
  6. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    I'd drill a hole and screw them in for best results.
  7. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    If they’re small and light and you don’t have pet or kid problems, some velcro is all you need.
    Wayne A. Pflughaupt
  8. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    Should I use the double-sided adhesive that came with the stands?
    Thanks.
  9. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    I suppose, but I expect that velcro would be more substantial. I guess you can decide for yourself if "more substantial" is beneficial or not in your situation.
  10. Stephen M
    Stephen M Stunt Coordinator
    Sep 16, 2000
    169
    Obviously, the point of this exercise is to keep it from falling to the floor on your equipment or on your head. Do you feel lucky? If not,take Wayne's advice since its easy, cheap and foolproof. (Not you Wayne [​IMG] )
  11. JamesAH
    JamesAH Agent
    Jan 17, 2004
    41
    I just realized the if I use the adhesive I cannot remove or move the wires withut ruining everything. Velcro it is. Thanks for your help.
