Moulin Rouge skip & freeze
Discussion in 'DVD' started by Tom Oh, Aug 28, 2003.
  1. Tom Oh
    Tom Oh Second Unit
    Jul 11, 1999
    253
    I had posted this on Moulin Rouge DTS problem thread but that one seems too long with 8 pgs.
    I am having a severe freeze/skip/pixelation problem with my Moulin Rouge disc. It occurs near the end of Ch 19 (Like a Virgin)where the layer change is. I use Sony 9000ES and this is the first disc to do so. I checked on my portable Toshiba SDP-1000 and the same problem occurs. Disc surface is clean and without a scratch. Has anyone else experiecnced this with their disc? Do I have a disc rot?
    BTW, I also see a DTS sync problem as well. This is a shame since DTS sounded so good.
  2. Britton
    Britton Supporting Actor
    Jun 3, 2001
    912
    4
    I'd say you have a bad disc.
  3. Tom Oh
    Tom Oh Second Unit
    Jul 11, 1999
    253
    Just my luck. It played fine on first 2~3 viewing. I put it on couple of days ago to check if my disc had the DTS sync problem. I found a bigger problem[​IMG]
  4. MarkHarrison
    MarkHarrison Supporting Actor
    Nov 14, 2002
    597
    I had the exact same problem. It made the second half of the movie nearly unwatchable as it kept happening throughout the rest of the movie. The good news is I swapped it for a new set and it works fine.
