Moulin Rouge Release Dates (1 Viewer)
Why is Moulin Rouge being released in Australia 2 weeks before it is being released in America?
The release date for Moulin Rouge on R1 is the 18th December (according to play247.com) and the release date for Moulin Rouge on R4 is the 5th December (according to Ezydvd.com.au)
Is there going to be any difrences between these versions and which one to you reccomend I buy?
Cheers,
AliP.
Hendrik
...perhaps the facts that the Director is Australian, the leading lady is(was?) Australian, most of the cast (singers, dancers, extras) and crew (DoP, production designer, costume designer, make-up persons, lighting crew, etc. and so forth) very likely is Australian, and the film was made entirely in Australia ... as I started out to say, in my usual long-winded way, perhaps these facts have something to do with the DVD of the movie being released in Australia first?...
Ok a bit of a stupid question.... One learns from his mistakes!
Now that we have cleared up why its being released in the land of Oz first is there any reason for me holding out for the Region 1 release ?
Hendrik
...ahh... well... this being a musical, you must take into consideration the 'Chipmunk Effect' inherent in PAL transfers (lots of music and singing in this movie!!!) ... but don't forget the 'Judder Effect' that NTSC transfers are saddled with (lots of pans and sweeps following the dancers in this movie!!!)...
...one just can't win, can one?!...
Chipmunk Effect?
Judder Effect?
Excuse my ignorance but what are you tripping on about ?
And i take it from the response that there would be no reason to wait for the Region 1 release?
Hendrik
Alistair... where have you been all these years?... don't tell me you have never heard the pros and cons of the PAL vs. NTSC controversy?...
[Edited last by Hendrik on November 14, 2001 at 09:54 AM]
Hendrik
...this is what I wrote in another thread, last August:
...PAL runs at 25fps (movies shown in theaters run at 24fps) hence the c.4% speed-up (picture and sound)...
AFAIK there's no way around this, it's just a 'fact of life' (one, BTW, that a few hundred million people around the world have been happily living with for the past 50-odd years!)... wouldn't worry about it too much...
...if you want to get 'technical', take a look here:
http://www.digieffects.com/frames/transferfilmtovideo/filmtovideo.html#ShootingSuper35 . . .
Thanks Hendrik,
I now know what your tripping on about. :)
I was aware of the speed-up issues related to pal and the resolution issues related NTSC. I however have never heared of it being refered to as the 'Chipmunk' or 'Judder' effect.
Do you think there will be any diffrence between the features contained on the disks ?
Also thanks for the links, I didnt know the exact maths involved but I do know.
[Edited last by Alistair Paterson on November 14, 2001 at 11:27 AM]
Julian Lalor
The R4 version of Moulin Rouge has the same special features as the R1 version, down to the DTS track. However, the DVD has NO subtitles at all (which means it is a R4 dedicated DVD and not R2/4). There is, however, a video commentary for the visually impaired.
Mikael Soderholm
Stockholm, SWEDEN
Mikael Söderholm
Hendrik, you're right as far as there is nothing to do about the speed-up...however, this doesn't necessearily mean the pitch has to change as well. There are ways to handle pitch-correction in PAL transfers, although I'm not sure if and how often they are actually used...
I have a pre-order for Moulin Rouge R4 (anything to get this one early) but I'll compare it to my copy of the soundtrack, and if it sounds pitched, I'll sell it and get the R1..
/Mikael
No! Try not. Do... or do not. There is no try.
