Motorized Opening Door????
Discussion in 'Home Theater Projects' started by DarrinG, Oct 8, 2003.
  1. DarrinG
    DarrinG Extra
    Jul 28, 2003
    21
    Has anyone tried to make a automatic door for their HT.
    Any help/ideas would be great
    Darrin
  2. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    I believe these are available commercially for handicapped access, but I'm sure they're not cheap... probably several thousand dollars minimum. It's quite a sophisticated mechanism with limit/overload switches and clutching mechanisms to avoid smashing someone in the door and allowing manual operation in the event of power failure.
    A very ambitious DIY project indeed! I've never heard of anyone attempting it. But by all means keep us posted on progress if you decide to.
  3. MichaelDDD
    MichaelDDD Supporting Actor
    Sep 29, 2003
    616
    Mike
    Linear Actuators.
    They are available with every rating from 10 to 1,000 pounds of lift. A small linear actuator with about 100 pounds of lift force would be more than enough to open your door. They run off 12V power (i.e. car battery/power supply.
    You'd have to fabricate the bracketry and such out of angle iron, and install the limiter switches, but it would be much cheaper than having one commercially installed.
    Just an idea. [​IMG]
    ps
    Linear actuators are used extensively in car audio applications to move amp racks, open/close panels, etc.
