More reciver help please :sigh:
Discussion in 'AV Receivers' started by Petros_M, Apr 28, 2004.
  1. Petros_M
    Petros_M Auditioning
    Apr 6, 2004
    6
    Ok I was kinda dead set on the Yamaha 5790 but then I saw this. Can someone please help me out here should I really go for the 5790 while this one seems pretty good. I guess what I'm asking for is opinions on the two
    Oh I got the Klip quint system(got them for a steal so could pass it up) and this is only from me bedroom incase you needed to know. Here are the specs for the two recivers.
    5760.
    Stereo Power per Channel 110W x 7
    Total Harmonic Distortion 0.04%
    Dolby Digital Decoder Yes
    DTS Decoder DTS-ES
    Dolby Pro Logic Decoder Pro Logic II
    DSP Soundfields Cinema DSP
    5.1-Channel Input 7.1 input
    Rear A/V Inputs/Outputs 7 S-video
    Front-Panel A/V Inputs Yes (with S-Video)
    S-Video Inputs/Outputs 5/3
    Component Video Input/Output 2 inputs
    Multiroom Capability No
    Remote Control Type Preprogrammed
    Phono Inputs No
    Digital Outputs 1 optical
    On-Screen Display Yes
    DTS ES Discrete 6.1 Yes
    DTS ES Matrix 6.1 Yes
    DTS NEO 6 Yes
    HDTV Compatibility Yes
    Video Up Conversion Yes
    5790:
    Station Presets 40
    DTS Decoder Yes
    DSP Soundfields 27
    Digital Inputs 5 optical / 3 coaxial
    Stereo Audio Inputs/Outputs 4/0
    Rear A/V Inputs/Outputs 7 s-video
    Front-Panel A/V Inputs A/V input
    Multiroom Capability Yes
    Remote Control Type Learning remote
    Phono Inputs Yes
    6.1-Channel Input Yes
    DTS 96/24 Yes
    DTS NEO 6 Yes
    Video Up Conversion Up to component
  2. Wayde_R
    Wayde_R Stunt Coordinator
    Aug 25, 2003
    244
    Since nobody replied I'll give it a whirl.
    Dude! These are both awesome receivers! Don't beat yourself up over the differences between these two, most people would LOVE to have to decide between them.
    Both decode up to the extended surround formats, have 7.1 inputs (hi-res city) and seven discreet amplifiers built in. What more could you ask?
    DSP pre-sets are garbage. THD, SN ratio are all irrelevant, after all we are talking about 21st century solid state electronics.
    So it comes down to multiroom capability. If you want it, go for the 90. If you don't, save money on the 60.
    You didn't mention power rating on the 90 but the 60's 110x7 is as good as Home Theater needs and the 90 doesn't likely have any appreciable difference.
    But, like most consumers you want to know which one is "better". Personally I judge receivers worth the old fashioned way. I pit them against each other upon a scale and the one to tip the scale wins. Weigh them, the heavier one has a better build quality. 'nuff said
    Wayde
  3. Matt Baldwin
    Matt Baldwin Auditioning
    Apr 13, 2004
    9
    I agree!! I have the 5660 and I could not be happier. Althought I just got it two months ago not knowing that the 57's would be coming out.
    The 5660 is 90x6 which is more then enough for my room, it also sounds very good. The dialogue is clear as well as much of the surrounds. I compared it to the Denon 1804 and was looking at some HK models overall it is at least as good as those. Yamaha has a good reputation in the home theater industry and should be a good choice for a reciever.
  4. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Have you had a chance to audition?
