More Questions regarding RP56
Discussion in 'Archived Threads 2001-2004' started by Luke Zhang, Feb 5, 2002.
  1. Luke Zhang
    Luke Zhang Extra
    Jan 18, 2002
    20
    Sometimes during a transition from a scene to another, the my RP 56 lags a little bit. Why is this the case?
    What does Anamorphic or Non-Anamorphic mean?
    Why doesn't the RP56 has the scale functionality? I am pretty sure mine has an option to turn to different ratios in the Action Menu.
    And finally how could I tune this player for the best Interlace quality? (I don't have a PS TV) Should I still get the Composite cables?
  2. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Anamorphic, only in terms of DVD authoring, usually means that during a downconversion of a 1.78:1 ratio High Definition telecine master to a 1.33:1 ratio NTSC or PAL D-1 digital tape, the 1.78:1 image is electronically squeezed into the 1.33:1 frame.
    When that squeezed image is stretched back out on a 1.78:1 widescreen TV for proper viewing you get approx. 33% more horizontal resolution since fewer or no pixels were used for the black letterbox bars on the top and bottom of the screen compared to a straight (non-anamorphic) 1.33:1 transfer where the electronic black letterbox bars take up more of the available pixel real estate, leaving less for the actual picture.
    The RP-56 does not do auto scaling of non-anamorphic DVDs to pseudo-anamorphic presentations for widescreen TVs that lock into the FULL mode because it uses the SAGE/Faroudja de-interlacing chip. That model of chip does not include this feature (I don't know if Faroudja is working on that problem or not). The RP-91 does, however, because that is a function of the Genesis de-interlacing chip Panasonic used for that player.
    You want to use component video cables as long as your TV supports component video inputs. The next best thing is to use S-Video. Unless you absolutely have to use it, composite video is the one to avoid.
    Dan
  3. JohnHN
    JohnHN Stunt Coordinator
    Dec 20, 2000
    91
    The lag in scene transition may be a layer change. (Most new DVDs have information encoded on two different layers that are glued together.) Layer changes on the 56 are slower than on some other players.
