More on S-Video & Component Cables
Discussion in 'Archived Threads 2001-2004' started by Phil Wyeth, Mar 25, 2002.
  1. Phil Wyeth
    Phil Wyeth Extra
    Jan 14, 2002
    17
    I read somewhere that S-Video is the same or virutally the same as component hook-ups. Is this true? Anyone., thanks.
  2. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    No, S-video is not the same as component. The former separates luminance (brightness) from chrominance (color), but the latter further separates chrominance into blue and red components.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Home Theater Magazine did a comparison of the 3 video connections and came up with the following results:
    Composite (single RCA cable): baseline
    SVideo (funny keyboard connector): 20% better than Composite
    Component (3 RCA cables): 25% better than Composite
    They noted that the results were obtained using a "reference" 50" RPTV. A smaller TV shows LESS difference, while a larger TV shows MORE.
    While people have run SVideo 30-60 feet - this is a long run for 2 30-gauge wires inside the cable. The 3 wires for a Component video cable set are typically 18 ga and are better separated. So Component tends to be better for long runs.
    And HDTV - the only way to send Progressive or HT signals is with a Component video cable set.
    The prices on component cables ARE a bit shocking. But the smart people (all of us on HTFourm [​IMG] ) know to go to the custom internet sites and order cables made with the same stuff used in the Broadcast & Production Studio industries.
    For about $75 you can get a good 6 foot cable set that rivals the $280 Monster Video 3 cable sets sold in the stores.
    So if you have a choice (or have a HDTV that is going to do funny things to the video signal), you really should go for a Component hookup.
    Some sites to check for cables are:
    www.bettercables.com
    www.wickedcables.com
    www.catcables.com
    www.ebay.com (search for "Canare")
    Good Luck
  4. Phil Wyeth
    Phil Wyeth Extra
    Jan 14, 2002
    17
    WOW!
    Amazing help, thanks guys
