More HL2 problems, this time with TCP/IP
Discussion in 'Gaming' started by Timon Russo, Dec 9, 2004.
  1. Timon Russo
    Timon Russo Stunt Coordinator
    May 10, 2000
    213
    So I finally replaced my old 10Mbps 4-port hub with a new Linksys Wireless-B broadband router. I plugged my 2 wired PCs in the back (I don't have a highspeed internet connection yet) and made the 1 change required to get the computers talking: Obtain an IP address automatically. This is the what the instructions said. Previously, I had specified IP addresses for the 2 PCs on the network. Now, when I launch HL2, it takes forever, then gives me a box that says "Updating steam..." and never does anything. There is a cancel button. I can cancel and launch Steam directly, but nothing happens (although it DOES launch a process...).
    I finished the game twice, and I wonder if I should be continuing to spend so much time trying to get my totally-legitimate and over-priced game to continue running. But if you could humor me and tell me how I might get around this, I would appreciate it. Or is there a Steam setting, or (gasp) hack that would help me out here?
  2. Tom Keels
    Tom Keels Stunt Coordinator
    Aug 11, 1999
    166
    You may have to do some port forwarding on your router. I did and it made a world of difference. But mine worked before I did it to. Is it possible that your router is blocking access to the port that steam uses?
