More "Digital amplifier powered" receivers coming out?
Discussion in 'AV Receivers' started by Chris PC, Mar 7, 2004.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    The Panny XR25/45 were intersting to read about. I like the idea of slimmer and more efficient. Are there any more receivers of this type coming out from any of the manufacturers? The Panasonic receivers, and I believe there was another brand, were receivers which apparantly sounded surprisingly good. I have a Marantz SR6200 and high sound quality is important to me, so I'd be critical of the sound, but I'm curious if there is any trend in the digital amplifier direction. If its done right, I think its a good idea.
  2. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    The XR70 is going to replace those Panny models.
  3. HoiT
    HoiT Agent
    Jan 23, 2004
    45
    I read from the Newform research site that the Panny amp sounds very good and is cheap. Just curious, where can one pick up one of these amps, do you know?
    HoiT
  4. Rory J.
    Rory J. Auditioning
    Mar 5, 2004
    4
    HK is due to release soon 2 digital receivers; the DPR 1005 & DPR 2005. The only difference I can find between the 2 is that the 1005 is 70 watts & the 2005 is 120 watts.
  5. Rich Wenzel
    Rich Wenzel Supporting Actor
    Aug 9, 2002
    556
    isnt sony using some hybrid power amps or digital amps these days?
    Rich
  6. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Rich,
    Yes they are. There are at least 3 receivers STR-DA9000ES, 5000ES, 3000ES with digital amplifier stages. I don't recall if the 2000ES has one as well.
  7. Dom P
    Dom P Stunt Coordinator
    Dec 30, 2003
    87
  8. TomCW
    TomCW Second Unit
    Jun 4, 2002
    339
    Notice the THD levels on these digital amps? Most are higher than analog amps by a significant margin. I think the Sony STR DA 1000 is analog (100 W) with a THD of .09% and the DA 2000 is digital (120 W) with a THD of 0.6%.
    Tom
  9. Dom P
    Dec 30, 2003
    87
    Higher distortion is the nature of the Class-D amp. That's why they have only been used to power subs where you can't hear the distortion like you can with mids and highs.
  10. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Although I consider myself critical, I don't live by specs alone anymore. THD of less than 1% is usually pretty good. All other things being equal, if you can tell the difference between 0.09 and 0.6% THD (about 0.5%) by listening, that would be impressive. But of course, all other things are never equal. We could argue all day about what the limits are. I'm hoping as there are more and more of these amps, the distortion will drop as the designs improve.
  11. Rich Wenzel
    Aug 9, 2002
    556
    Anthem, Conrad Johnson and McCormack rate their amps at 1%
    sunfire rates theirs at .5%
    rich
  12. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    YAMAHA already has at least one out, something #200 & only available here in Silver I belive, ~{tho a progressive DVD player is on board.
    100 x 5 I belive, with limited controls and hook ups compared to typical AVR's & also contains a built in fan on the rear.
    Very thin and deep like the Panasonics. Actually thinner as I remember...
    Their may be other digi Yamaha's currently out.
    They are said to be working on pure digital powered stand alone AV-Receivers.
    Someone else may have more specific information on them.
  13. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Again, I want sound quality too, but I'm happy to see stuff coming out. Hopefully it will be good. Fewer noisy fans too.
