David Barteaux
- Jan 6, 2001
I have Canadian version. There is a 1 sec pause which seems like layer change. I have Panasonic RP-91. The bass on the THX stampede intro is very powerful on my Bag End sub
The bad news: My Panny A-112 won't even recognize this disc.FINALLY! After all the posts in here, someone has my problem.
My H/K DVD50 played the trailers at the beginning, but after that, nothing. The player would just stop. After my 3rd try with it, it finally told me "DISC ERROR".
Disc Two of M-Inc plays fine. VERY frustrating.
Ok so this is a layer change, but what "genius" authored this disc and decided to put a layer change with like 5 minutes left in a movie?
There's only one authoring package that allows the author to decide where the layer change goes. And it is the most expensive one out there. Head and shoulders above the rest, as I understand it. Almost no authoring house has it, for that reason. From what I hear, it doesn't offer any other advantages, either. But I'm no expert; just passing on what I am told, and what I've read here on HTF.
As to that disc's performance on my systems:
* Mintek players (both versions: super cheap version and version with Karaoke): Perfect performance on both. No detectable layer change. I'm really surprised. Especially as I've seen layer changes on these before.
* Panasonic A-120: Detectable layer change at that time index; nothing unusually long, and certainly no lockup
* PC (Athlon 900Mhz running WinME):
**DVDPlay utility free with WinME: Works perfectly, as with Mintek players above...no detectable layer change
**InterActual Player (comes on MI discs): Like the DVDPlay and the Minteks, works perfectly...no layer change pause
**MediaMatics (popular DVD player, came with my Compaq): VERY surprisingly, there was a detectable layer change at that time index. No different that the one on the Panasonic A120 player. I've never seen a layer change on that soft player before, but then it isn't used too often. I assume that soft player doesn't use the buffering technique I mentioned, or else there's something about the authoring of the layer change on the MI disc that defies the buffering. I'm not sure...but it's certainly weird.
I hope this helps some of you! Good Luck! Call 1-800-72-DISNEy to complain.
The bad news: My Panny A-112 won't even recognize this disc. Just a "no play" message and on the screen "this type of disc cannot be played, please insert another disc."BIZARRE DISCOVERY: Well, for some reason I kept on fooling around with this disc and may have found a work-around for anyone with this particular problem (and a Panasonic player). In my frustration, I punched the open/close button on the player twice in a row. That is, I put the disc in the tray, closed it, got the "no play" message, pressed open then close again (so the tray came out, then went back in)...then the disc started and seemed to play fine.
I do get the pause/freeze for the layer change in this player, and it may have been slightly longer than the usual change, but it kept on playing.
So for anyone with problems reading the disc period, you might try this.
