Monster Video 3 Cables: Real Quality or pure Marketing
Discussion in 'Playback Devices' started by HermannMasser, Sep 18, 2003.
  1. HermannMasser
    HermannMasser Auditioning
    Sep 12, 2003
    7
    I am looking for your opinion on Monster Video 3 Component and S-Video cables. I am setting up my HT using an Infocus Digital Projector, I will be connecting a DVD Player via component, Digital Cable Box (Explorer 3200HD) via S-Video and via component for HDTV Signal and would like to know if Monster Video 3 are really good cables or if it is only a marketing thing, Also, if anybody has experience with custome cable companies that would sell same or better quality and less expensive than Monster I would greatly appreciate your input. I am planning to use a JX-S111 video switch with it, if anybody has one input will also be gretly appreciated.
    Hermann
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    You can find better deals online, but one thing you can say about Monster cables is that they are well constructed. Some say they are overpriced--perhaps they are, but they are quality cables.
    I use Video 3 for DVD & HD and they do the job.
    DJ
  3. Frank joe
    Frank joe Stunt Coordinator
    May 28, 2002
    155
    try calling straightwire i think they are much better than monster. i have owned both of these cables and i will stick with straightwire from now on. yes they are a little pricy but consider the money that as spent on your other gear. they make a very good cable to any lenth you want.
    frank
  4. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    There are any number of on-line cable makers that will give you much better bang for your buck than Monster. A few to consider are:
    signalcable.com
    bluejeanscable.com
    heartlandcable.com
    And there are others. Try doing some searches and you will find more info.
    I am not sure how many of them make S-Video cables. Personally I think you will probably do just as well using the composite feed from your cable box, due to the nature of cable signals. I notice no improvement going from composite to S-video using a 3100HD box.
    Mark
  5. HermannMasser
    Sep 12, 2003
    7
    Thanks for your replies.
    I while back I purchased a cable from pacific cable but I wasn't able to find any reviews on theiur quality, has anybody used them before?
    Hermann
  6. Jigesh Patel
    Jigesh Patel Stunt Coordinator
    Jun 16, 2003
    137
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Basically they're all 75 ohm video cables and all perfectly suited to pass a fairly easy signal from your DVD player. For the lengths you're likely considering, RG-6, RG-59, thinner...it makes no difference.
  8. HermannMasser
    Sep 12, 2003
    7
    So what about the Phyton Cables? I saw those are 75 Ohm cables and they cost a fraction of what the Monster Video 3 cost... any input on those?
    Hermann
  9. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    as long as the center conductor is copper, one piece or stranded, and you're shielded it's up to you how much or how little you want to spend. i've no idea what phyton cable is.
