Monster Speaker Cable at 33% discount
Discussion in 'Hardware Classifieds' started by Sanjivnpatel, Jun 26, 2003.
  1. Sanjivnpatel
    Sanjivnpatel Agent
    May 16, 2003
    28
    Hi;
    I have following two products for sale. MOnster Cabel and Monster Banana plugs. Monster cable is left over from my purchase of 500 ft spool and Monster Banana plugs. These two are NOT compatible, so if you are planning to buy these two for each other please don’t buy.
    200 to 300 ft of SuperFlat™ Navajo White Easy-to-Hide Speaker Cable
    This is the description from Monster website.
    * Flat profile for unobtrusive runs along baseboards and under carpet.
    * Flexible design for easy routing in corners and around doorframes.
    * Paintable/stainable Navajo White jacket matches all interiors.
    * Over 1,000 fine copper strands maintain high frequency response for improved sound.
    * Decorator-friendly for home theatre systems and other out-of-wall hookups.
    Click on the link for additional details.
    http://www.monstercable.com/productPage.asp?pin=81
    Monster sells this for $1.50, I’ll go for $1.00. For longer length, I am willing to go even lower.
    I also have 7 sets (for 7.1 setup) of Monster Lock™ Monster Bananas Modular Speaker Cable Termination
    See the link for description.
    http://www.monstercable.com/productPage.asp?pin=603
    Monster sells this for $12.50 each, I’ll go for around $5.95, if somebody is buying all 7.
    Thanks.
    Sanjiv
  2. ChrisChap
    ChrisChap Stunt Coordinator
    Apr 25, 2003
    85
    FYI - Circuit City sells that cable for 0.60 cents per foot.
  3. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    The 2 Circuit City stores near my place sell the SuperFlat™ Mini™ Navajo for 60 cents per foot. The 12 gauge SuperFlat is $1.50 around here.
  4. Sanjivnpatel
    Sanjivnpatel Agent
    May 16, 2003
    28
    ChrisChap;
    I'd appreciate if you get your facts straight. I have not seen the one in CircuitCity but I am pretty sure it is 16 gauge. It is described on following link, Monster sells it for $0.75 per ft. Monster calls it SuperFlat Mini. "MINI" is a keyword, which implies 16 gauge.
    http://www.monstercable.com/productPage.asp?pin=82
    One I am selling is 12 gauge one. See the link below.
    You are comparing apples and oranges. That if you know the difference.[​IMG]
    I hope you come out and accept your mistake about your post.
    Sanjiv
  5. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
  6. Sanjivnpatel
    Sanjivnpatel Agent
    May 16, 2003
    28
    Craig ;
    Thanks for pointing that out. As it is ChrisChap did not do his home work twice before posting. First posting false information and second not reading the rules of posting. Anyway, 'almost' all forum members are smart enough to recognize the difference between 12 gauge and 16 gauge cable.
    Sanjiv
