John H
- Nov 27, 1998
I use 2 power centers in my system. A Current Design PC-8 for my main unit. I use one of it's outlets to trigger a Monster HTS-3500
I was doing some subwoofer measuring when all of the sudden I heard a constant low level high pitched sound. (the subwoofers have nothing to do with the 3500. They each have their own dedicated circiuts.) I traced it down to the Monster unit. The entire front panel display was out. LED indicators as well as the AC meter.
I went outside and flipped it's dedicated breaker off and back on hoping the unit might reset itself. I also tried to reset the breaker on the rear of the unit. It did not help. I pulled the unit from my system and tested it several times. No front panel lights, no meter function, no rear outlet operation, just the noise.
There was no evidence of a power surge or brownout when the unit failed. My PC-8 has an alarm that sounds when in protection mode.
I believe the unit just failed.
I guess I will look up my sales receipt and see if the unit is still under warranty.
I am going to pick up a replacement 5100 later today. I don't want my system down for the holidays.
