Monster F-Pin cables?
Discussion in 'Archived Threads 2001-2004' started by Jake T, Sep 7, 2001.
  1. Jake T
    Jake T Stunt Coordinator
    Jul 4, 2001
    225
    Do these cables make a big difference when you connect them from the wall connector of your satellite or cable to your TV or SVHS?
    [​IMG]
    Jake T
    --"The Things You Do In Life Echo An Eternity"
    ----Russel Crowe, Gladiator
  2. Elbert Lee
    Elbert Lee Supporting Actor
    May 24, 2000
    501
    I've had better luck with the M1000fv, which use a similar connector. It's very secure, but won't necessarily give you a better picture.
    Elbert
  3. Jake T
    Jul 4, 2001
    225
    Jake T
