Monster Cable
Discussion in 'Archived Threads 2001-2004' started by Haris Ellahi, Oct 13, 2002.
  1. Haris Ellahi
    Haris Ellahi Second Unit
    Oct 30, 2001
    485
    What are banana clips, spades, etc.?? What are they used for? Do I need them?
  2. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
  3. Haris Ellahi
    Oct 30, 2001
    485
    Thanks!
    Which type of speaker wire connector do you recommend? I have the Klipsch Reference Series 7 speakers and I will have the Denon AVR-4802 A/V receiver.
  4. Bill Kane
    Feb 5, 2001
    1,359
    Banana plugs for the convenience.
    They cost around $4 a pair average. When the time comes to get speaker wire and component cables for the DVD and other cables and wire, a comprehensive order at accessories4less.com or partsexpress.com can include the bananas in one shipping/handling package.
    Banana plugs typically unscrew in the middle where about 1/2in of bare wire is inserted and folded back down over the threads then rescrewed. No soldering. You may want to avoid DUAL plugs. There's a 50-50 chance they wont fit the spacing on yr spkrs or receiver's binding posts.
    I mentioned these U.S. online suppliers, but note you're in UAE. So I dont know where you find your supplies. Best of luck. Inshallah.
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I am moving this to Connections/Accessories/Tweaks.
  6. Haris Ellahi
    Oct 30, 2001
    485
  7. Haris Ellahi
    Oct 30, 2001
    485
    One more question...
    Is it okay to have one end of a speaker cable with spades and the other end with banana clips?
  8. Bill Kane
    Feb 5, 2001
    1,359
    MonsterCable.com shows their varieties and I believe there are premade connectors.
    Mixing spades and bananas are fine. You likely will have to do it yourself.
  9. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    No offense, Bill, but my jaw dropped when I read you response (final line).[​IMG]
  10. Bill Kane
    Feb 5, 2001
    1,359
    hmmmm...you object or approve of the concept of good will toward men.
    Or the concept of mixing spades and bananas?[​IMG]
  11. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Remember that the important thing is to do a neat wiring job because small strands of copper can create a short and damage your equipment. Banana/spades/pins all allow you to wire up the ends and do a neat job BEFORE crawling behind your equipment to attach.
    Radio Shack makes some nice dual-bananas (xxx-308) for behind your speakers. And Bill is correct that the spaceing is not standardized so try 1 set before buying 5.
    For behind the receiver I like the single bananas from Radio Shack (xxx-306) because the dual-bananas stick out about 3" which is too far in my rack.
  12. Iver
    Iver Second Unit
    Sep 23, 2002
    324
