Monster Cable speaker connectors
Discussion in 'Archived Threads 2001-2004' started by Haris Ellahi, Feb 4, 2003.
  1. Haris Ellahi
    Haris Ellahi Second Unit
    Oct 30, 2001
    485
  2. Haris Ellahi
    Oct 30, 2001
    485
    By the way, which size spades should I get for my Klipsch RF-7 speakers? Medium, Large, or X-Large?
  3. Andy Young
    Andy Young Stunt Coordinator
    Nov 30, 1999
    78
    Hmmm. Did you actually read the links you posted? :b Well, in reading the links you posted, the spades come in a pack of 2 pair and the bananas come in a pack of 2 pair or a bulk order of 50 pair.
    I can't answer your other question, as I'm not familiar with the speakers. However, the spade sizes are based on their widths. Presumably, you could measure the diamter of the post to which they'd be connected. From this measurement, you should be able to choose a suitable spade size.
    Good luck.
  4. Haris Ellahi
    Oct 30, 2001
    485
    I did read it but was confused with the "ea." after the price. I thought it mean "each."
    So, each $12.50 pack contains four connectors, right?
  5. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    Correct.
  6. Haris Ellahi
    Oct 30, 2001
    485
    Thanks.
    However, will the Parasound HCA-2205AT amplifier support those Monster Cable banana connectors?
  7. Donnie Eldridge
    Jan 3, 2001
    761
    You shouldn't have any problem using those connectors.
  8. Jason Caudill
    Jason Caudill Stunt Coordinator
    Aug 7, 2001
    153
    Haris,
    You have to own monster speaker cables with the monster lock system in order to use these. They are not for terminating bare speaker wire. I just wanted to make sure you knew that. Jason
