Monitor doesn't work with my KVM switch.
Discussion in 'Archived Threads 2001-2004' started by Mike St.Louis, Feb 11, 2002.
  1. Mike St.Louis
    Mike St.Louis Supporting Actor
    Sep 22, 1999
    518
    I just got a Startech Starview KVM switch (SV411K) to move between my Windows 2000 and Linux PC's.
    For some reason though, my monitor doesn't work through it. I have a KDS Avitron 17" model which has worked well for me. When hooked up through the switch the monitor showes compressed garbled text. After a few minutes the display would show a box with this message:
    Out of Range
    Hf 30 KHz - 70 KHz
    Vf 50 Hz - 160 Hz
    Current Frequency
    Hf 120.1 Hz
    Vf 75 Hz
    I cannot bring up the monitor controls before this message appears and when I was finally able to bring them up I couldn't find a setting for changing frequencies.
    I stuck in a friend's older monitor - a Sony 15" Triniton model and it works fine.
    Suggestions??
  2. Thom B
    Thom B Stunt Coordinator
    Jan 11, 1999
    213
    I ran into this awhile back with an Apex switch. If I remember properly the solution was to change the screen refresh rate in display properties.
    - right click the desktop and select properties
    - click on the settings tab
    - click the advanced button
    - click the monitor tab
    - drop the refresh rate to 60 or so
    T
  3. Mike St.Louis
    Sep 22, 1999
    518
    Hmm. Wouldn't that just change the settings for Windows?
    I was thinking that it was a setting on the monitor itself brought up through the digital controls.
    I can use the monitor if I don't go through the switch. There doesn't seem to be a setting for frequency though.
    Are you saying I can set the refresh rate in Windows and it will change it on the monitor? I had the monitor hooked up to my laptop which has a refresh rate setting of 60 Hz.
  4. Thom B
    Jan 11, 1999
    213
    I'm not sure what the exact mechanics are behind the process. I assume that the switch can't pass the signal properly if the refresh rate is set too high.
