Modifying gang boxes
Discussion in 'Home Theater Projects' started by don costanza, Jan 30, 2004.
  1. don costanza
    don costanza Agent
    Nov 19, 2003
    28
    Well, after spending some time searching the archives I haven't found an answer to this question so I thought I'd start a new thread.
    Starting the pre-wire phase and would like to drill a 1 1/4" hole in the box instead of using the punch-out tabs. Will this cause undue pain and suffering on my part when the inspector arrives?
    Thank you for your time on this issue...
    Don
  2. Chris Hovanic
    Chris Hovanic Supporting Actor
    Jan 3, 2003
    545
    Though I am not an expert in code your part of the country or mine for that matter, I am under the impression that the tabs are there to hold the wire so that it does not back out of the box. In the old metal box days they had punchouts that you put a clamp connector which holds the wire.
    I would recommend a call or visit to your inspectors office before you continue.
  3. don costanza
    don costanza Agent
    Nov 19, 2003
    28
    Thanks Chris for the reply... that was our consensus as well. I saw a picture of someone that did what we are interested in doing but can't find that info, figures...when I need it I can't find it.
    Best Regards
    Don
  4. ErnieST
    ErnieST Auditioning
    Jan 21, 2004
    6
    Why do you need the large hole? Are you running a conduit to the box? As long as you properly terminate at the box with the appropriate fitting, I don't think there's anything in the code that prohibits making a larger hole.
    My 2002 NESC is at my office but I can check tomorrow.
    ErnieST - licensed master electrician
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    What is going into the box, Don? If it's low voltage (RG-6, phone, etc.) you don't need a box at all.
  6. don costanza
    don costanza Agent
    Nov 19, 2003
    28
    Sorry for the delay in getting back with everyone...the reason we were going to need to put a hole in the box was to connect the flex-conduit to it. ErnieST even mentioned this in one of his posts.
    Thanks for the input...
    Best Regards
    Don
  7. Gary Silverman
    Gary Silverman Stunt Coordinator
    Aug 12, 2000
    121
    Don, As long as the flex terminates at the box with a flex connector, you'll have no problem with any inspector, no matter what you're bringing into the box.
  8. don costanza
    don costanza Agent
    Nov 19, 2003
    28
    Thanks Gary for the input. We were to go out this weekend and start putting holes in the studs but I made the call (to the relief of everyone helping)to hold off until this coming weekend. Just too darn cold even with space heaters...
    Best Regards
    Don
