Modem connection keeper-aliver? (1 Viewer)
Daren Welsh
Great name, don't you think? I'm looking for a program that will keep a modem connection alive. I'm trying to d/l some large files and if I leave the room and let it work, the connection will get cut off, most likely from the ISP. If I stay on the computer and keep browsing this forum every few minutes, it keeps the connection alive, but I can't do that all day and night. I'm sure there's a program or two out there that periodically requests data to keep the ISP from auto-disconnecting. I figured someone here would know of one to recommend, preferrably one without spyware or unneccessary bulk.
Tekara
try opening the command prompt and using
"ping www.yahoo.com -t"
this will send out a constant ping to yahoo.com and should keep your connection alive.
or if your worried about sending never ending pings try using a chat program like msn messenger or yahoo chat, they send out a ping every few seconds as well to test for connection.
Ken Seeber
If you have Norton Systemworks it has a program called Connection Keep Alive built into it.
Shawn O
Would your connection stay alive if you set outlook(or what ever you use) to retrieve your email every 2 minutes or so?
Just a thought.
Staff online
Rvolkman
