Robert Silge
- Jan 8, 1999
I posted a thread on this in the HT hardware, but no luck, or no one knows. So I thought I'd go into more detail here, and see if that doesn't entice a response.
I have a DIY sonosub. I am thinking of buying the Sony SA-WM40 as well. I am wondering about the effects of using both at once. Since I'm sure they won't have the exact same response to a signal, will this muddy my sound, and create interference?
My other thought is to hook the Sony (assuming it's not as capable a sub as mine, which I hope it's not) in at line level as a rear sub. Does this make a noticeable improvement? I could also put it at the back of the room on the same channel as my main sub, and hope sheer distance would overcome any interference issues (it's about a 25' room I think).
Since I'm going to do some sub surgery on my sono, I want the Sony as a backup in case I both something, but I'd also like to use it in tandem if possible.
Thanks guys,
-Rob
Thanks guys,
-Rob
