luxasia
- Sep 29, 2008
- Michael
Hi..
new entry to this forum..
Background - Just bought onkyo SR875 amp and need help to maxed my new investment.
My previous amp (Technics with Dolby Suround Pro Logic) has been serving me well for the last 12 years. I used 2.1 Cervin Vega with 12" woofer in zone 2 and 3.1 Bose acoustimass system supported by 2 average rear speakers in zone 1 for my home theater. Both are pasive woofers. Today just bought Jamo sub woofer 300.
Questions;
1. I dont want to store my current speakers and plan to use them in combination. My thought is as follows; use the bose for front - left, right & center supported by the jamo sub 250. For surround left & right use the cervin vega and also the passive bose woofer at the back making it a 5.2. I was told that I could do the following for the suround;
a) from amp to passive woofer then out to surround speakers
b) from amp to surround speakers then to the passive woofer.
Is this good arrangment? Bose cube acoustimass speakers claimed they are 4-8 ohm max 200 watt. The cervin vega probably 8ohm 150 watt. my new onkyo output is 250 watt per channel.
2. Also thinking of standardising all speakers using bose. Keep the current one for front. To buy bose vs 30 package ( 1 x 100 watt center and 2 x 80 watt soround). If budget allows, will get 2 additional cube for sorround back speakers making my set up 7.2. However, read review on bose plastic quality and lack of midrange.
3. Due to the average/poor reviews on Bose speakers, should I replace all speakers with other make. Thinking of Jamo. Where I came from others are beyond my budget
Beside dvd, I also use ps3 for gaming and blue ray and for music, I'm into all from rap to heavy metal and occasionally jazz & classical.
Any suggestions welcome and highly appreciated. Thanks
Questions;
