Mix & Match HTS?
Discussion in 'Speakers' started by Greg Labate, Sep 5, 2004.
  1. Greg Labate
    Greg Labate Stunt Coordinator
    Jul 31, 2004
    52
    Do most out there buy their home theater speakers from one brand, or mix and match from different brands? Anyone have problems mixing brands?
  2. Tim Stumpf
    Tim Stumpf Stunt Coordinator
    Mar 3, 2004
    145
    The conventional wisdom is to match the front 3 speakers, i.e. center and left and right main within the same line of speakers from the same OEM. In other words, get the front 3 as a set that are meant to operate together. This will make for smooth and accurate panning effects across your front sound stage. The rears and subwoofer are less important as to matching. I think many people match brands because they buy sets of speakers all at one time and it just works out that way. My experince is that the subwoofer is most often from another company than the other speakers. A good sub should be able to integrate well with almost any other set of speakers because of the nature of low frequency sound. Hope that helps.
  3. Rick Cohen
    Rick Cohen Agent
    Mar 7, 2004
    28
    If you already have a mix and match set of speakers try them and use them before you go out and buy a whole new set. Invariably even with identical speakers, placement will change their sound characteristics to some degree as well as the adjacent surface materials.
