Puneet Cham
- Aug 14, 2002
Hi,
I've been browsing this great forum for some time so I can soak up as much information as possible before making the RPTV plunge. After some thought, I've decided on a 2002 Mitsubishi, but cannot figure out the difference between each series. Any help would be greatly appreciated. I"m looking to get either a 65" or maybe 73".
I talked to this guy from the "Great Indoors" and he said that basically the only difference between the 2002 diamond series and the 2002 platinum plus series is the high gloss cabinet. So basically I would be paying a $1,000 extra for looks.
Can anyone confirm this???
Also, he said that he would NOT go with a Mitsu with an integrated HD tuner because you would be locked in to it. He mentioned that a change in HDTV standards was on the horizon (he compared it to going from Dolby pro-logic to Dolby digital or something like that) and that by buying an integrated tuner I could only go to Mitsubishi for an upgrade rather than shopping around. He recommended the Gold Plus series.
I dunno. The more I read the more confused I get. Any advice would be great.
Puneet
Puneet
