Bill Austin
- May 8, 2001
Ok I have a Mitsubishi ws65907 TV, using the Mitsubishi sr hd5 HDTV box and a rooftop antenna in to grab the HDTV signal. I live in the Chicago IL area, I can pull in 5,7,9,32 in HDTV and it's AWESOME! for some reason though I can't get channel 2,,,,
But my biggest problem/question is that the picture I get is about 15% too big for the screen, bottom or top text seems to be cutoff.
When the signal is true HDTV I can't adjust the format size for HDTV thru the TV (says it cant perform the function) and by using the sr hd5 thru direct tvs menus to adjust picture size again it says the same thing, (when getting a HDTV signal you cant change the viewing format - zoom, stretch, crop etc), it's a great picture and all, but the size of each of the HDTV signals (all channels) seems about 15% too big for my screen, (almost as if I had hit some zoom button once) and I can't figure out if there is anyway to adjust this.
Has anyone else seen this type of thing?
I admit I am new to all of this but have done a lot of reading thru both the TV and decoder box manuals and haven't come across a way to fix this if it's even possible.
Bill
Bill
