mitsu tweek
Discussion in 'Archived Threads 2001-2004' started by JackL, Dec 14, 2001.
  1. JackL
    JackL Auditioning
    Dec 13, 2001
    I just got a new mitsubishi with the buillt in HD decoder. I've people write about the mitsu "tweek", what is it. If anyone can help me out, great. thanks jack
  2. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    Jack:
    There is no one "Mitsubishi tweek." A tweak is a subtle change you make in one of the numerous adjustable parameters that gives you a better picture. A tweak can be an adjustment in the regular menu, the service menu or even partially taking the TV apart and refocusing or lining the TV with black cloth! If you to go www.hometheaterspot.com you will find more tweaks for Mitsubishi TVs than you would have ever imagined possible. The best part is that there are step-by-step instructions and knowledgeable people to ask when you have questions.
    Good luck.
    SMK
  3. RyanL
    RyanL Stunt Coordinator
    Mar 7, 2001
    110
    I think that the "tweak" that you're refering to is the red push problem, but as Steven pointed out, all that is discussed very thuroughly at hometheaterspot.com
