Mits 'features'?
Discussion in 'Archived Threads 2001-2004' started by Ed St. Clair, Oct 2, 2002.
  1. Ed St. Clair
    Ed St. Clair Producer
    May 7, 2001
    3,320
    Anyone up on these Mits RPTV 'features'?
    1. Color Tuned Shield.
    I'am not 'into' protective screens. Anyone know if it's easily removable or is it the greatest thing since sliced bread?
    2. HVSM.
    I'am not 'into' scan velocity modulation, either. Is it easily defeatable or is it the cat's meow?
    Thanks.
  2. Jim Can
    Jim Can Stunt Coordinator
    Jan 28, 1999
    62
    What model are you interested in? I have the 55411 and the anwser to your questions are
    1. yes
    2. yes
    I like the protective screen I think it looks good plus I have kids so nuff said.
    As far as hvsm I'm not sure about that, you'd have to look at one and try out the settings to your personal taste.
  3. Ed St. Clair
    May 7, 2001
    3,320
    Thanks too all!
  4. Jim FC
    Jim FC Stunt Coordinator
    Feb 5, 2001
    211
    The VSM is defeatable through the user menu on most of the Mitsubishi models EXCEPT the ones Best Buy carries. The screen is easily removeable, but it is "color tuned," which according to Mitsu means that it is designed to keep ambient room light from entering the set through the screen. You can remove the protective shield, but depending on your room, removing it may decrease contrast.
  5. Bruce Hedtke
    Bruce Hedtke Cinematographer
    Jul 11, 1999
    2,249
    I removed the shield (easy) and I wouldn't go back. If you have photos or posters encased in glass behind you, the reflection off those from your television will show up on that protective screen and it is quite distracting.
    Bruce
