Mits DD8040- 'Black Level' Question
Discussion in 'Playback Devices' started by James Edward, Jan 18, 2004.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    I just replaced my Tosh SD-5700 with the DD8040. Picture quality on the Mitsubishi seems better to me- colors appear more saturated, and the picture seems slightly sharper and with more depth.
    However, I'm a little unsure of the 'black level' control on the player. Turning it to 'off' yields a much better picture; deeper blacks, better contrast, and better color.
    But... The player always seems to default to 'on' for the black level after shutting it off or changing out the disc. Can this be defaulted to 'off', or should I be using the brightness control on my TV(Tosh 57HX81)?
    On a related topic, does it matter whether my TV's 'Cinema Mode' is set to 'Film' or 'Video' when using the player in progressive mode?
    Thanks for reading and any replies...
  2. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Yeah I hated that DD-8040 "bug" - the black level off won't stick! I took it back because of that reason and got a used Faroudja-based Panasonic XP30 that doesn't have that problem. As far as the TV's interlacing mode, the film vs video is only used for interlaced sources so it will be ignored with progressive mode since the DVD player is doing the de-interlacing.
  3. James Edward
    May 1, 2000
    855
    I was hoping for some trick to make black level off stick- oh well...
    After watching it some more this morning, I'm going to keep the player- I LOVE the picture quality improvement.
