Mits 55411- What should I use to clean the screen?
Discussion in 'Archived Threads 2001-2004' started by James Herrod, Dec 1, 2002.
  1. James Herrod
    James Herrod Stunt Coordinator
    Nov 27, 1999
    54
    Surprisingly enough, the manual didn't seem to address this. Is it safe to use Windex or should I just use a damp cloth on the screen? Thanx! Jim
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
  3. Matt Wallace
    Matt Wallace Second Unit
    Feb 20, 1999
    400
    Jack is right. However, if your set is like my 55311, it has a protective shield, which isn't nearly as sensitive as a lenticular screen. I've been using the pump spray version of Endust for Electronics for a few months and gently wiping away my kids fingerprints with a cloth diaper and a light spray or two and it has worked great. One tip, though.. DO spray the cleaner on the rag. Don't spray on the tv directly,as it may drip inside and leak down onto the machinery located at the bottom of the Mitsubishi!!! Good luck [​IMG]
    Matt
  4. James Herrod
    Nov 27, 1999
    54
    Yea, I actually have a can of that stuff in my cabinet so I'll give that a try. Thanks everyone for the info. Jim
