Mistake on the menus for Transformers Sea 2 PT1
Discussion in 'Archived Threads 2001-2004' started by JohnS, Dec 7, 2002.
  1. JohnS
    JohnS Producer
    Jan 17, 2001
    4,861
    166
    4,110
    John Steffens
    There is a mistake on the scene index menus of Transformers Season 2 PT1
    Insert Disc 2 and go to the scene index.
    Then page to the episode of Enter the Nightbird
    and look at each individual scene window.
    Now, page ahead(the next episode) to A Prime Problem
    and look at its each individual scene window.
    You will notice that they share the same scene windows
  2. Mijang
    Mijang Agent
    Oct 6, 2001
    27
    You will also notice that the episode numbers listed under the episodes are also incorrect. For example, the first episode of the set is listed as episode 16 -- season one had 16 episodes, so the first episode of season two should be 17. The episode numbering mistakes are rampant throughout the set.
    But regardless I think Rhino did a great job on this set compared to season one.
