Mission impossible?
Discussion in 'Speakers' started by LaurenT, Sep 6, 2005.
  1. LaurenT
    LaurenT Auditioning
    Sep 6, 2005
    4
    Hi,
    I own the following Yamaha A/V receiver: RX-V630
    I upgraded to a nice HDTV set and my speaker budget is shot.
    I have $400 to spend on main speakers (left and right channel), center channel and subwoofer.
    I would appreciate some advice and product recommendations that fit my budget.
    Typical use: Movies and video gaming.
    Rarely: Music listening.
    Thanks for any help you can give me.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
  3. LaurenT
    LaurenT Auditioning
    Sep 6, 2005
    4
    Thank you, John, for your recommendation.
    - I am not necessarily looking for something that will cause earthquakes.
    - I would like parts (main speakers, center speaker, subwoofer) that fit well together.
    - I would like to be able to put everything together without having to get a PhD first.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    No sub even if you spent all $400 on it, is going to cause earthquakes. Well maybe if you bought two of those Parts Express subs... [​IMG]
    The recomendation is sound though. Maybe Qty6 (3 pair, for complete 6.1) of the JBL E30's with the 12" parts express sub. Right at budget and pretty darn impressive.
  5. LaurenT
    LaurenT Auditioning
    Sep 6, 2005
    4
    You're over budget, John.
    $400 is the budget. [​IMG]
    Yeah, I know it sucks, but these HDTV sets aren't cheap. [​IMG]
    Oops...that price was for a pair...so you may be under budget... [​IMG]
    But do you really recommend using an E30 as a center speaker?
  6. LaurenT
    LaurenT Auditioning
    Sep 6, 2005
    4
    How about that combo?
    JBL E30 Bookshelf Speakers (Black)
    JBL EC35 Center Speaker (Black)
    JBL E150P Powered Subwoofer (Black)
    Right now, there is no way I can place rear speakers anywhere.
    Or what about that combo?
    - Fluance Dynamic Compact Three-way Hifi Speakers AV-F3
    - Fluance Home Cinema Acoustic Center Channel Speaker AV-SC
    - Fluance DB-150 10 Inch 150 Watt Low Frequency Powered Subwoofer
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    I am one that uses the same exact speaker in every location. The E30 makes an awesome center, I actually like it better than any of the center channel specific speakers JBL sells.
  8. John S
    John S Producer
    Nov 4, 2003
    5,460
    PS: With that budget, anything besides the $138 Parts Express 12" would almost be a crime. [​IMG]
