Mark-C
- Oct 6, 2000
I was swapping the wires about on my sub and I forgot to turn it off, in the manuel it says that it must be turned off before any wire swapping is done.
It stopped working, I opened it up and inside a little fuse had blown, could I have caused any permanent damage or should replacing the fuse sort it out ?
