Missing Outlook Messages, But Have Folders
Discussion in 'Computers' started by Rob Landolfi, Nov 18, 2005.
  1. Rob Landolfi
    Rob Landolfi Stunt Coordinator
    Feb 26, 2002
    182
    Following a recent XP reinstall, everything is back to where it should be, but I can't find some of my Outlook mail messages. I transferred my outlook.pst and archive.pst to another drive, then put them in the corresponding folder on my C: drive and had all my current items. Messages beyond several months are missing, though the folders that contain(ed) them are present.
    I'm thinking it's some kind or archiving issue, but I haven't had any luck in importing from my old folders.
    I do have my old XP install in a Ghost image, so I should be able to rescue the files if necessary. Any other thoughts?
    Thanks for any insight.
  2. Rob Landolfi
    Feb 26, 2002
    182
    I think I had a bad setting in my Archive.pst prior to my reinstall that deleted items over 6 months old... must have been a default setting as I don't ever remember choosing that.
    I think I've lost some old mail, but my .pst is pretty huge so I can't imagine that so much has disappeared.
  3. Rob Landolfi
    Feb 26, 2002
    182
    Problem solved... I remembered that I had tried moving my working .pst and archive off my C: drive to another partition and went looking there. Found the files and noted that the archive was about 5X larger than what it was in my backup file. When I copied the larger file back to my (working) folder in the C: drive, everything reappeared in the archive.
  4. StevenFC
    StevenFC Second Unit
    Aug 23, 2003
    481
    Glad to help. [​IMG] [​IMG]
