Mirage omc2 or omc3 question?
Discussion in 'Archived Threads 2001-2004' started by Ricky c, Dec 17, 2001.
  1. Ricky c
    Ricky c Stunt Coordinator
    Aug 28, 2001
    157
    I'm getting the Mirage om7's but can't decide on the center speaker.It will go on a shelf in my wall unit.The omc2 is omnipolar and the other is direct.The shelf is above my t.v. but there is the upper shelf{crown molding } above this shelf.Would i be better off w/the direct center since it's not omnipolar or would it even matter.
  2. Dzung Pham
    Dzung Pham Second Unit
    Mar 10, 2001
    271
    I just got the OM-C2 and the manual specifically says that you should allow 10-12 inches of space to the back and the sides of the unit. Maybe you can get loaners for each, try both out and see which one you like.
  3. MikeH1
    MikeH1 Screenwriter
    Oct 25, 2000
    1,492
    I think the OMc2 is the one you might want. I have the MC2. It an older model and is direct but does have some beef to it. If money is not a concern, the C2 is the one. But if you can, any reputable Mirage dealer will let you try both. Thats always the way to go, if you can.
  4. Ricky c
    Aug 28, 2001
    157
    I'll actually have approx 7-9" to the sides and about a foot to the rear wall.
