mini-review of PSX controller adaptor for XBox
Discussion in 'Archived Threads 2001-2004' started by Michael St. Clair, Mar 10, 2002.
  1. Michael St. Clair
    May 3, 1999
    6,001
    I picked up the 'Innovation' controller adaptor last night; the one that lets you use PSX/PS2 controllers on your XBox. It was $25 at Funco.
    Here are some quick thoughts.
    It doesn't work with original PSX steering wheels (neGcon compatibility standard). I doubted it, but had to try it for myself.
    It works with a PS2 Dual Shock controller, and the lower shoulder buttons map to the triggers on the XBox controllers. The pressure sensitive (256-position pseudo analog) functionality does work, giving you analog control. However, it seemed a little twitchy to me (which could just be me). The functionality of the analog sticks and the other buttons was fine, and the rumble feature seems to work pretty well.
    I may take it back, I was basically gambling on the steering wheel functionality. But for standard pads, there will definitely be some fans of this adaptor.
  2. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Michael -
    Have you tried it with a PS2 joystick? I was thinking about picking up a Shadowblade stick and a converter. I already have a PS2 to Dreamcast converter, so then I'd have a joystick for 3 systems. [​IMG] But of course it is all moot if it doesn't work very well....
    -Dave
  3. Larry Seno Jr.
    Larry Seno Jr. Supporting Actor
    Feb 28, 2002
    527
    Where might someone who doesn't have a Funcoland nearby go to pick up these?
    Thanks!
  4. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    Funcoland == GameStop == Babbages == Software Etc, by the way.
  5. Michael St. Clair
    May 3, 1999
    6,001
    Not sure about the joystick...does look like I'm keeping it since I don't have time to return it.
    I would think that it would work fine.
