Might have messed up on the Oversqueeze fix for the Wegas...
Discussion in 'Archived Threads 2001-2004' started by Adam_Garris, Jun 17, 2002.
  1. Adam_Garris
    Adam_Garris Supporting Actor
    May 28, 2002
    517
    I had everything right, but I forgot to change turn of the enhanced mode before I saved. I reset the stuff, but it is still changed. Did I majorly screw my new Wega up? what do I do to amend what I did?
  2. Clint B
    Clint B Second Unit
    Jul 14, 2001
    317
    I'm pretty sure you can just go back into the service mode, turn off the enhanced mode using the normal method, and then save your change. To my knowledge that won't screw anything up and it won't erase the settings you've changed.
