Phil Olson
- Jun 30, 1997
I am building a WMTMW speaker using the CCS WR125S as the mids. The problem is that the driver requires so much volume for a flat response that it adds considerable size to the box.
If I bring the volume for those drivers down to a reasonable level, it puts a .8 dB hump in the curve at around 165 Hz, (Q=.925). Since the pass freq will be about 900-1000 Hz or higher the hump should be more than 30 dB down if I'm correct, (12 dB/oct).
Anything wrong with this? I could increase the box some more and cut the hump further but considering the above would it be worth it?
Phil
Phil
