Metal Studs for Framing in HVAC Ducts
Discussion in 'Home Theater Projects' started by MichaelBran, Jul 1, 2004.
  1. MichaelBran
    MichaelBran Auditioning
    Jun 21, 2004
    2
    Guys,
    I am building my HT now and was thinking of using metal studs to frame in the HVAC ducts around the room to make a tray ceiling. My question is do metal studs cause a problem when it comes to sound in the room? I am worried about a tin type of sound.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    That won’t be a problem. There might be problems with rattling and buzzing, however. Just make sure everything is good and tight, and perhaps use some sort of sealant between metal-to-metal contact points to act as an insulator.
    Wayne A. Pflughaupt
  3. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    I haven't heard too much difference. One store I worked at that sold high end stuff had metal studs
  4. Jim_Ski
    Jim_Ski Agent
    Mar 16, 2004
    31
    we built a soffit using metal studs as well, and I haven't noticed any 'tin' sound or buzzing.
    For fire-code reasons we did have to seal the ceiling within the soffit area, and I used a spray foam to fill the gaps. Just something you may have to keep in mind.
