CraigF
is there something wrong with the framingToo bad WFRR doesn't have a framing problem, or BTTF a timing problem...sorry, but I would be amused
The dvd freezes multiple times for about 10 seconds. This is probably due to the fact that I played it on my Sony DVP-S9000ES as this problem is similar to the problem many sony player owners had with the Spy Kids 2 dvd.Chalk me up as another S9000ES owner who's having freeze-up problems with this release. I'd have to go back and pinpoint exactly where it locked up, but it happened once (that I noticed), and it was fairly early on in the movie.
One other thing I noticed is that the subtitles frequently "lock-up" as well -- they get stuck on a particular line, and stay that way until I cycle thru the subtitle options again to the English.
Sigh. Does that mean returning this disc to Best Buy won't fix the problem after all?
I have this disc and on my Sony 9000, I was listening to the audio commentary but the Spanish Subtitles kept showing up even though the Subtitles were turned off, but it would only show up when the subtitles were showing you what was written on a newspaper or building or something like that. It also had a 20 second freeze up at the layer break. I have almost never seen a layer break on this machine.I am having exactly the same problem but with a JVC player and the French subtitles. I had to turn on the English subtitles and then turn them back off for the movie to play correctly.
No Freezing on my Toshiba SD-3109, but the Flickering is MADDENING! It appears to be on every live action scene where animated characters were added so could it be attributed to the process used to merge the two together?I noticed the same thing. I suspect this is from the original elements and not a result of a bad transfer. I wish I still had my original release so I could do a comparison. I don't remember seeing flickering on the original release, but the transfer quality wasn't as good either. Could be that the leeser quality release masked some of the flickering effect, or perhaps I just didn't notice it so much since I wasn't looking for it.
Other than the flickering, I had no other problems playing the new release on my Toshiba SD6200.
I'll have to try it on my Pioneer DV414 this weekend to see if it has any problems.
JimmyK
Re: the flickering...
Folks, this is the wonderful world of good 'ol photochemical optical effects. These "flickering" shots are at *least* one generation removed from non-optical elements. The only way around this is to do a grounds up restoration of WFRR, going back to all the original elements, scanning them into the computer as high-res files and digitally compositing them.
Cheers,
Felix
I can't speak to the dvd as I'm not going to buy it, but I did watch the laser disc on Tuesday, and saw no flickering.I have the LD and the new DVD. The differences between scenes of opticals and non-opticals are much more pronounced on the new DVD. Unless I'm misunderstanding the descriptions of "flickering" in this thread, I think this is what's being noticed.
BTW - while I did notice the quality differences from shot to shot, I was not overly distracted by them, even on a 92 inch screen. I think the new WFRR DVD is pretty darn good. My one annoyance is that the audio is quite harsh. It has always been harsh and shrill, but I was hoping for a more balanced track in the re-mix.
Cheers,
Felix
