Melissa Etheridge DVD- Am I really hearing 96khz/24bit?
Discussion in 'Archived Threads 2001-2004' started by Martin Fontaine, Dec 22, 2002.
  1. Martin Fontaine
    Martin Fontaine Supporting Actor
    Aug 15, 2001
    626
    I bought the Melissa Etheridge DVD Set (Live and Alone) and on disk 2, there are 2 tracks in 96/24. In my player's manual it states that if the disk is Copy-Protected it will downsample to 48khz. Playing it I noticed it's clearer than what I'm used to and I hear no difference between the Digital (Toslink) connection and the analog one.
    So is this part of the disk NOT Macrovision flagged by any chance?
  2. Judy Y
    Judy Y Stunt Coordinator
    Feb 27, 2000
    119
    I have a DVD-audio player and I can only play it through the analog outs on my player. It is flagged as the higher resolution on my player. If you do not have DVD-audio capability, I don't think you will get the high res playback. Anyone else have any thoughts?
  3. Craig F
    Craig F Second Unit
    Jul 5, 2001
    276
    Craig
    Many receivers have a display mode, where it will tell you what it is receiving over the digital link. Check your manual.
  4. LanceJ
    LanceJ Producer
    Oct 26, 2002
    3,168
    On my Panasonic DVD-R31 it can play 96kHz/24bit tracks at full 96/24 resolution either through its analog outputs OR its digital output. But: if the disc is copy protected the digital output either will shut off or it will downsample to 48/16. The player indicates resolution via its on-screen display.
    Note!: I am not sure if Macrovision affects the digital AUDIO portion of a dvd though.
    LJ
