Measuring Speaker Ohms
Discussion in 'Archived Threads 2001-2004' started by Richie-C, Jun 26, 2002.
  1. Richie-C
    Richie-C Agent
    Jun 7, 2002
    27
    Can someone tell me how to measure the speaker ohms to tell whether or not I have a short in one of my speakers?
    Do I just measure across the +/- posts of the speaker with an ohm meter while driving the speakers to see what ohms I am getting.
    What should the reading look like for a 8 ohm compatible speaker? What would a shorted speaker or wire look like on the ohm meter?
    Rich
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    what's happening? you could simply run test tones specific to the driver in question and listen, look for movement. ex a 100 hZ sine wave for the woofer...10 kHz sine wave for the tweeter. the resistance of a speaker depends upon the frequency. an 8 ohm speaker simply means that the nominal rating is 8 ohms over a particular frequency range, say 40-18kHz. there's more to it, but let's deal with your problem.
  3. Richie-C
    Richie-C Agent
    Jun 7, 2002
    27
    My problem is that my receiver is shutting down (49TX) and the technical service guy seemed to think it might be due to a short or that my speakers are getting down to less than 3 ohms.
    I am not a techie so I am looking for help.
  4. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Are you driving the receiver pretty hard in 5 channel or 2 channel? What kind of speakers do you have? Many do go down to 3 ohms or below.
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    ok, so what you're saying, is that with your speakers connected, the receiver shuts down, yes? if so, there may well be a short in the cables/speakers. how did you connect your speaker cables, bare wire? examine the connections and the wire itself carefully. Disconnect the cables from the receiver end and make sure there's no stray wire bridging the connections. Do the same for the speaker end. If all is ok, leave the wires disconnected. Power up and try listening with a set of headphones. Still OK? add the speakers one at a time. Keep them in phase now! Let us know!
  6. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Do they shut down the moment you hook up your speakers, or only when you're playing them loud?
    I would not put a multimeter across a speaker's binding posts. That would send DC voltage into the speaker, and depending on the crossover inside, could cause some damage to the drivers. Even if it doesn't work, speakers aren't meant to take DC, so it wouldn't be a good thing. Plus, like Chu said, an 8 ohm speaker doesn't necessarily have 8 ohms resistance at DC, the impedance varies depending on the frequency of the signal you feed to it.
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    well maybe a D cell battery would be ok, no?
  8. Saurav
    Feb 15, 2001
    2,174
    Depends. What's the DC resistance of a voice coil? AFAIK, the impedance of the driver comes mostly from the inductance of the coil. If the speaker has a simple crossover with no series resistors..... It'll probably be fine though... a speaker should be able to handle several amps of current, right?
  9. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    So what happened? Inquiring minds want to know.
  10. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    A multimeter would put such a small amount of voltage through your speaker that it won't hurt. It will give you the DC resistance of your speaker, though, which is probably close to the minimum point of the impedance curve. For example, the DC resistance of a Kit281 (4 ohm nominal) is 2.8 ohms, which is the minimum impedance at 25 Hz. The impedance of a speaker is the DC resistance plus reactance (combination of inductance, capacitance, and frequency). The woofer usually has a peak at the resonance of the sealed box, or twin peaks surrounding a dip at the resonance of the vented box, with a rising curve due to inductance thereafter. The tweeter has an impedance peak at its Fs, then a rising curve due to inductance as well.
    What speakers do you have? The 49tx might just not be up to the task if you're playing loudly into inefficient 4 ohm loads... especially if they're set to large.
  11. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I think the 49tx is Pioneer's top of the line thx certified receiver putting out somewhere in exess of 100 watts/channel.
