me against salesman, help! (1 Viewer)
MichaelDW
I asked this once allready but I'll try again. I only have room for a 5.1 surround setup, is(dts,dd,prologic2) the only things that I need if I never plan on haveing 6.1,7.1 or whatever they come up with next? and is there a feature or a way that I can use the back surround speakers as mains when someone is trying to sleep?
Alex Yang
Michael,
1. Is this the ONLY thing I need...? (More than likely YES, for the forseeable future...) 1yr to 2 yrs
2. Is there a feature to use the back surround speakers as mains...? Unfortunately NO, as the speakers are "wired" from the back of your receiver as SURROUND speakers, if you wanted to use them a "primary" speakers you would need to "REWIRE" them to the "Speaker B" terminals instead...
I have the same problem when my four year old is trying to sleep, hence the reason why I purchased Sennheiser HD600 headphones and enjoy my surround sound via Dolby Digital Headphone out (Denon 5803)...
Good luck,
-Alex
Rob Rodier
If you dont use the multichannel input on the receiver you could feed the analog record out or a second analog out on the source (if applicable) into the rear l/r of the 6ch input. Kinda wackey but it would work.
-rob
Zacha R
The Denon 3802 and up let you reassign the surround back amplifiers as mains in a second zone.
NHCondon
